It is currently Mon Jul 28, 2025 9:48 pm
 Post subject: Installing pickups
PostPosted: Fri Aug 28, 2020 12:23 pm
First name: Oris
Last Name: Morton
City: Franklinton
Anyone else get really tense when drilling out that huge 1/2” hole in a beautiful finished (acoustic)guitar?
 Post subject: Re: Installing pickups
PostPosted: Fri Aug 28, 2020 12:30 pm
Nope...:)
PostPosted: Fri Aug 28, 2020 12:35 pm
First name: Oris
Last Name: Morton
City: Franklinton
meddlingfool wrote:
Nope...:)
My 3rd one.
PostPosted: Fri Aug 28, 2020 1:17 pm
For the jack you mean? Get a step drill bit and the proper reamer and you will never worry again.
These users thanked the author jfmckenna for the post: olmorton71 (Fri Aug 28, 2020 2:58 pm)
PostPosted: Fri Aug 28, 2020 4:59 pm
First name: Tim
Last Name: Mullin
City: Shefford
State: QC
Zip/Postal Code: J2M 1R5
Done it many times and have the correct tool(s). Most endpin units are actually designed for a 15/32” hole, so that 1/2” is looser than ideal. Stewmac carries the ideal reamer for the job. Expensive. I waited until it was 15% off. Still expensive.
The other issue with installing endpin jacks is that the tail block may be too thick and require a counterbore. Various ways to handle this. You’ll find posts on the forum about modifying a spade bit as a counterbore, but the slickest solution is a rear spot facer. I drill out the original endpin hole to 5/16” to accommodate the pilot shaft (indexed for correct depth) for the 7/8” spot racer and prepare the face. Then the Stewmac reamer to make the 15/32” hole. In a busy shop, these pay for themselves in no time.
These users thanked the author Tim Mullin for the post (total 2): bcombs510 (Sat Aug 29, 2020 1:55 am) • olmorton71 (Fri Aug 28, 2020 11:45 pm)
PostPosted: Fri Aug 28, 2020 8:40 pm
First name: Freeman
Last Name: Keller
As Tim said, get the reamer and you'll never worry. Expensive, yes, it takes a couple of installations to amortize it but not splitting a D-35 makes it worth while. And like Tim also mentioned, I had one guitar with a very thick end block and made a pull counter sink bit out of a spade bit. Mine is home made, kind of mickey mouse but worked fine.
These users thanked the author Freeman for the post: olmorton71 (Fri Aug 28, 2020 11:45 pm)
PostPosted: Fri Aug 28, 2020 9:39 pm
First name: Tom
Last Name: Rein
City: Saline
+1 for step drill. You need the one that is long and has about 1/2" facets. Stop at 7/16" and do.the rest with the StewMac reamer.
Stay with the happy people.
--Reynolds Large
These users thanked the author TRein for the post: olmorton71 (Fri Aug 28, 2020 11:45 pm)
PostPosted: Sat Aug 29, 2020 8:15 am
First name: Tim
Last Name: Mullin
City: Shefford
State: QC
Actually, if you’re using the Stewmac reamer, there’s no need for a step drill bit. The reamer is very sharp and does a quick enlarging an existing endpin hole, or you drill a 5/16” pilot for guitars without an endpin.
These users thanked the author Tim Mullin for the post: olmorton71 (Sat Aug 29, 2020 10:10 am)
PostPosted: Sat Aug 29, 2020 10:57 am
15/32" is 11.901 mm.
Metric step drill to 12 mm cost = $15 or less
Stewmac reamer cost = $87
Never seen the need for the reamer myself, considering I had the step drill anyway....
PostPosted: Sat Aug 29, 2020 12:31 pm
First name: Tom
Last Name: Rein
City: Saline
Sure, your way will work. A step drill from Harbor Freight costs less than $10 and does the lion's share of cutting. Plus, you can start with a 3/16" pilot hole drilled with a twist drill (to minimize tearout on inside block). I figure my StewMac reamer will last much longer by shifting most of the drilling to a disposable cutting tool. Also, many are using Baltic Birch as a tail block and the glue used is not especially kind to cutting tools.
--Reynolds Large
PostPosted: Sat Aug 29, 2020 6:04 pm
I drill on the drillpress with the LeeValley brad point bits before the back and top are installed. Works well for me.
PostPosted: Sat Aug 29, 2020 6:11 pm
I still use a step bit with the reamer. I drill the end pin screw hole out with a 1/4in bit then step up to 7/16th and finish with the reamer.
PostPosted: Sat Aug 29, 2020 11:27 pm
First name: Oris
Last Name: Morton
City: Franklinton
I’m gonna pre drill my next tail block. Pre fit the jack.
